Hops like a bunny
Old Apr 30, 2011 | 09:37 PM
juicestain's Avatar
Default Hops like a bunny
So I have BMR lower control arms and panard bar (non adjustable) with sportlines and when I slam into 2nd it hops like bunny, what can I do to fix this? Car is a 2000 M6 SS.
Old Apr 30, 2011 | 10:03 PM
MillerTime85's Avatar
Lower Control Arm Relocation Brackets.
HWI's Avatar
HWI
Do you have the relocation brackets with those LCA's? If not, I recommend to do the relocation, it cured my wheel hop.
Old Apr 30, 2011 | 11:16 PM
juicestain's Avatar
Awesome thanks, I'll try this out.
Old May 2, 2011 | 08:28 PM
ncfastls1's Avatar
Agreed with the LCA relocation brackets. I had horrible wheel hop before when I had some eagle f1 gs-d3's that were going bald. When I got new tires, it helped but only because they had more traction. I got brackets when I installed my strano springs and it completely eliminated any wheel hop.
Old May 3, 2011 | 07:27 AM
UMI Performance's Avatar
I also agree, I would try a set of relocation brackets. Since you are lowered the control arm angle is changed, using the brackets will correct the control arm angle and increase your traction.
I hope that helps,
Ryan
Old May 3, 2011 | 08:26 AM
amr84ss's Avatar
I have a question about the relocation brackets. Does anyone have a picture of the control arms before and after installing them?
