Rag Joint
Old May 15, 2011 | 10:16 AM
Silver2000WS-6's Avatar
Default Rag Joint
I have read where the rag joint may be my loose steering problem on my 2xx,xxx mile 1995 TA. I see where a lot of people put an Unbalanced Engineering Rag Joint Eliminator in to fix the problem. My question is will this not create a noise or vibration doing away with the rubber? Also if I go back with a new stock replacement will I just be wasting my time due to my headers dissipating so much heat into this part? Thanks for your help.
Chase
Old May 15, 2011 | 11:06 AM
3 pedal SS's Avatar
No noticable noise or vibration. Only tighter steering. IMO a stock piece would be a waste of money.
Old May 15, 2011 | 12:13 PM
camar0corey's Avatar
It is a nice piece, I don't notice any more vibration.
Old May 15, 2011 | 10:06 PM
FirebirdStud's Avatar
just installed mine today, along with the strano springs and swaybars and koni shocks. Driving it tomorrow to get an alignment, and then Ill be able to tell you what its like.
Old May 17, 2011 | 06:26 PM
Thanks for the input, sounds like eliminating the rubber doesn't cause problems.
