Another Driveshaft Safety Loop thread
Ok, here's the basic rundown of the setup I'm planning to use when my car goes back together soon, and have most of the pieces picked out that *SHOULD* fit together since space is at a premium under these cars... UMI Torque Arm Relocation Kit/Crossmember for T56, re-use my SLP Adjustable Torque Arm, currently have SLP bolt on SFC's (not a big deal, car has a 6-point roll bar welded inside) and I will be running ARH 1-7/8x3" headers with an ARH Y into a custom made 4" single exhaust. I don't think a loop that goes up into the tunnel will work, since I need as much room as possible for the big 4" pipe, so I've been looking at the UMI and BMR DSL's since the bracket drops and would fit UNDER the exhaust. Just not sure which would leave the most clearance for a 4" pipe and still have everything else fit together. If need be, I can remove the SFC's so it'll fit since I've got a 6-point welded in.
So does anyone see any problems here? Which DSL would fit best with the T/A in the stock location with the ARH Y and big 4" exhaust?
