Sqeeky shocks HELP!
Old Jun 7, 2011 | 09:20 AM
cwdub4's Avatar
Default Sqeeky shocks HELP!
My front shocks sqeek like there is no tomorrow, but only when its very hot outside...can i spray some WD-40 just unitl i can afford to get some good shocks?
Old Jun 7, 2011 | 09:52 AM
mike171562's Avatar
you sure its your shocks and not balljoints or bushings?
Old Jun 7, 2011 | 12:42 PM
cwdub4's Avatar
ya im sure its the shocks, it only sqeeks wen i go over speed bumps or something like that
Old Jun 7, 2011 | 02:54 PM
z28bryan's Avatar
Do you have poly bushings on your front swaybar?
Old Jun 12, 2011 | 03:26 PM
cwdub4's Avatar
just say it was my shocks, can i or cant i put WB-40 on in the mean time till i get new ones?
Old Jun 12, 2011 | 07:28 PM
johnpate01's Avatar
Petroleum products typically are not nice to most kinds of rubber, but try it if you want. It probably won't work. Grease your swaybar bushings instead.
Old Jun 12, 2011 | 07:33 PM
vetteboy99's Avatar
Depends, what kind are they?
sjsingle1's Avatar
i have never heard of a squeaky shock either........to many bushings to blame that on
Old Jun 12, 2011 | 09:43 PM
cwdub4's Avatar
ok so if it is my bushings how much does that usually cost to replace?
Old Jun 13, 2011 | 07:25 PM
johnpate01's Avatar
If it's the swaybars, rear control arms, or panhard bar, take them off/out and grease them and the bolts if applicable. If it's the front control arm bushings, they will need to be replaced most likely. My bet is swaybar bushings.
Old Jun 13, 2011 | 07:33 PM
Juve PS's Avatar
I dont recommend that you put WD-40 on them. I used to have the same problem until i changed the shocks, so you're gonna have to deal with the noise.
