Bump Stops
IMO, rubber is better here. 3rd gen rubber bump stops work perfectly, direct fit, and can be found cheap at salvage yards (mine where like $4). The rubber in the 3rd gen stops is better and not that foam rubber stuff in 4th gens that falls apart. I used some fine grit sand paper to clean the stops, painted the metal plate, and then used some tire shine to make the rubber pretty and black.
