brake vibration
Old Feb 27, 2004 | 10:36 AM
FMLs1's Avatar
Default brake vibration
Hey everyone, hope you guys can help me with a brake problem. While stoping at higher speeds like 45-70 and a little at low speeds, my whole front end shacks like crazy. I did cut my slotted and drilled rotors and it really didnt help, so what else could it be? (could it be my pads, there pretty old.)
Old Feb 27, 2004 | 11:13 AM
Josh2021's Avatar
Could be that your rotors are warped, might want to check the pads aswell.
Old Feb 27, 2004 | 11:45 AM
zombie1's Avatar
Did you cut the rotors on of off the car? Off the car and on a brake lathe may add what is called stacked run-out,(brake arbor is a little bent), most manufactuers recommend turning rotors on the car if the are not hub and rotor design(old chevy 2wd pickup). If they were turned on the car, check wheel bearings, sometimes this can cause it..hope this helps
Old Feb 27, 2004 | 01:20 PM
Fulton 1's Avatar
To see if you have a problem you can measure the lateral runout on the front rotors.
Here's a little more info: http://www.brakeinfo.com/html/lateral.html
Old Mar 1, 2004 | 12:32 PM
FMLs1's Avatar
Default Thanks
Thanks guys for the input, i think ill do a total brake job with new pads and see if that works.
