Relocation bracket????
Old Jul 7, 2011 | 06:27 PM
dwfronk's Avatar
Default Relocation bracket????
I have a 01 Camaro M6 and have a BMR adj. torque arm and have just installed a BMR torque arm relocation bracket. I know i am going to hear more noise then normal but most of the time when i push the clutch in or let it out i get a THUD from under my feet. I was wondering if anyone else has this issue and if its normal.
Old Jul 7, 2011 | 06:40 PM
Element's Avatar
Sounds like something is loose, if you're getting that noise by just letting out on the clutch.
Old Jul 8, 2011 | 08:21 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Check and make sure everything is good and tight. What holes do you have the torque arm installed in on the torque arm relocation crossmember? If you have it set up high on the relocation crossmember there is a chance that it could make contact with the body.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
