SLP bilsteins/eibach kit question
But, I didn't even think about swapping the rear back to stock.
Will the front eventually settle? And gi8 did you put only the rear springs back in, or the stock shocks with them?
Are the height differences because of differences in the springs/shocks, or a difference in the car? What accounts for different ride heights with the same spring?
Here's a side shot of my car
But things like weight, what rear axle you have (10bolt/12bolt/9"), spring perch (worn or not), worn out springs, etc. Then wheel/tire height can make a car look lower/higher front to rear even if its not.
This is the SLP 70002 kit, not the prokit, and I just had it installed 2 weeks ago, so it shouldnt be sagging yet...
Also, my car is pretty much stock weight, only minor differences like the ORY. It is the stock 10 bolt, and I had the original springs and decarbons until 2 weeks ago with 103k miles on the car. If you look at the pictures, the rear sits like most people who have this kit, it's just the front that is basically the stock ride height still. My friend's 99 SS has this kit on and sits perfectly level.
There are a lot of variables that could be involved. Shocks don't effect ride height, all else equal on the car it should be springs only.
I do know that the Prokits have issues with sag though however, so not disagreeing with you there.
