Any need to replace the Power Steering Fluid?
Old Mar 2, 2004 | 10:11 AM
key master's Avatar
Default Any need to replace the Power Steering Fluid?
I did a search and found people were only replacing their power steering fluid if they were having problems: for example, it leaking or power steering noises. Is there any normal maintenance that needs to be performed? I only auto-x about once aper year if that (lately).
Any advice would be appreciated,
-Jim
Old Mar 2, 2004 | 10:02 PM
roy's Avatar
roy
-Jim
Ichange it after every track event , Pour out the brown and put in new Blue stuff, Pump has been going strong now for 6 years
Old Mar 3, 2004 | 09:06 AM
key master's Avatar
So you are saying to me to change it once per year. Are there any other opinions??
-Jim
Old Mar 3, 2004 | 09:58 AM
mitchntx's Avatar
I change mine 4 or 5 times a year ... but I do a LOT of track events
Old Mar 3, 2004 | 12:26 PM
key master's Avatar
OK, sounds like I should change it more often
Is there any way to determine if the fluid is bad? I just bought some "test strips" for my coolant and brake fluid which tells you if it's bad or not. Any test for ps fluid? Will it be darker or anything in color?
-Jim
Old Mar 3, 2004 | 01:56 PM
mitchntx's Avatar
If it smells burnt, like auto trans fluid, is how I tell ....
Old Mar 4, 2004 | 10:22 PM
M6HuggerSS's Avatar
where do you drain it from?
