SJM ABS Delete Kit Question
Old Aug 1, 2011 | 07:26 PM
Formula_LS1's Avatar
Default SJM ABS Delete Kit Question
Anyone know what the difference is for the 3 channel vs. 4 channel kits? Would both kits use the same lines, just different fittings? My car originally had a 4 channel rear, but I recently went to a 3 channel 10 bolt, so TCS and ABS no longer fuction. Would the 3 channel kit work? I would contact SJM directly, but they are closed until next Monday. Thanks for the help
Old Aug 2, 2011 | 08:05 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
The 4 channel setup would have two rear brake lines that run into the ABS box up front and a 3 channnel setup would only have one. That is the only real difference. How is your setup?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
