adj panhard noob checking in
Old Aug 2, 2011 | 04:49 PM
silver30th's Avatar
Default adj panhard noob checking in
so the car i recently bought has an adj panhard bar (not sure of the brand), but it has the rod ends on either side
i can move the bar with my hand until the stops hit...is this supposed to happen? it feels like there is a lot of of "hop" in the rear (even up to the shifter bouncing up and down)
whats the easiest way to ensure proper adjustment and should it be all lose like that?
thanks
Old Aug 2, 2011 | 06:20 PM
Element's Avatar
The bar itself is loose and slides both ways until it hits the jam nuts on the rod ends?
Old Aug 2, 2011 | 08:41 PM
silver30th's Avatar
yes, that's correct
Old Aug 2, 2011 | 09:05 PM
Element's Avatar
Something's definitely wrong with it. The rod ends should thread into the panhard rod, and there shouldn't be any side-to-side movement at all.
Old Aug 2, 2011 | 09:21 PM
silver30th's Avatar
let me rephrase myself...
i can spin or twist the bar, it's not moving side to side
Old Aug 2, 2011 | 09:39 PM
Element's Avatar
Ah. It should be able to do that - with double rod ends, I'd expect it's an on-car adjustable. You just need to get it set right (plumb bob and a level driveway is the easiest, use those and turn the bar until the axle is properly centered under the car) and then you need to put a wrench on the panhard rod and tighten the jam nuts to prevent the bar from spinning any more.
As far as "hop", a panhard rod shouldn't really affect that sort of thing except in corners.
Old Aug 3, 2011 | 08:01 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
You are fine, that is just how the rod ends work. They have a large range of motion and you should be able to twist the bar a considerable amount in both directions.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
