Identify These LCA Relocation Brackets
Thanks guys. Btw I already checked BMR, Spohn, & UMI and its none of them unless they are an older design. They are from 06' so that might be possible.
But I agree it looks like I can install them and only drop my lca's 3" with no other adjustments possible.
with only 2 thru (both plates) holes,they wouldn't have the 'adjustability' of a BMR.
what is the distance between the 2 thru holes,hole centerline to hole centerline ?
Metco says their lca's are direct bolt-in with no mods necessary, so nothing about the factory mounting design changes. Which would lead me to believe my UMI lca's would work, because they too are direct bolt-ins. This is something I want to ask Metco if they do reply back to me. Im hoping Metco saying their lca's are required is a marketing tactic.
Why is that? There is nothing mechanically/cosmetically wrong with them. New ones are $90-100 for bolt-ins.
Just looking visually the Metco brackets would need the LCA to be a tad small because they mount on the inside. BUT looking at BMR/UMI brackets you can tell there would be a small gap on each side of the LCA because they mount on the outside. Now to fix this you would tighten the LCA bolt until the gaps are gone. From what I remember when I installed my UMI LCAs they were a tad smaller than the stock lca mount and I snugged the bolt up until the gaps disappeared. Which should mean my UMI LCAs would fit snug inside the Metco bracket with no gaps and no stretching required.
I'm just thinking out loud, and I may be completely wrong, but after I pick up the hardware I need Ill try to install them. If they don't work Ill resell them and buy a set of UMIs..easy enough.
