Adjustable or non adjustable
Old Aug 9, 2011 | 07:36 AM
shaq_2500's Avatar
Default Adjustable or non adjustable
I was wondering which is best adjustable or non adjustable lower control arms, panrods and torque arms. I still have a stock 10 bolt for right now
Old Aug 9, 2011 | 08:19 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Is the car lowered? If not do you plan on ever lowering it? What are your plans for the car? I like to run adjustable stuff just incase you ever need it. There are certain situations you can get away with using non-adjustable stuff if you choose to.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Aug 9, 2011 | 09:06 AM
shaq_2500's Avatar
Car is not lowered, going to used it for street and strip, mostly a Sunday drive but still want to lay a good 60 foot down at the track
Old Aug 9, 2011 | 09:41 AM
BMR Sales2's Avatar
If the car is not lowered and you don't plan on lowering it you can get away with using a non-adjustable panhard rod and non-adjustable torque arm. I would go ahead and get a set of adjustable lower control arms along with a set of relocation brackets. The adjustable lowers will allow you to run a larger tire if you want and give you the ability to center up the rear end in the wheel well and the relocation brackets will add some positive anti-sqaut to the car which will help with straight line performance and traction. A good set of shocks will help you out but I would do that after you got the basci suspension parts covered.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Aug 10, 2011 | 12:24 AM
shaq_2500's Avatar
Ok thank Bmr sales
Old Aug 10, 2011 | 12:33 AM
shaq_2500's Avatar
Ok thank Bmr sales
Old Aug 10, 2011 | 08:50 AM
BMR Sales2's Avatar
No problem, if you decide you want some BMR stuff let me know and I can work up some pricing for you.
__________________
Glenn ***
Sales Tech
813.986.9302
