What to use to grind calipers.
Old Mar 3, 2004 | 01:10 PM
Donlin's Avatar
Default What to use to grind calipers.
I just bought a set of draglites and need to grind the calipers. I was wondering what type of disc do I need to buy. Also any tips would be greatly welcomed. Thanks,
Jay
Old Mar 7, 2004 | 03:14 AM
Roadrunner 45's Avatar
60 grit. You'll be grinding a lot. I kept spraying black paint on mine before I trial fit the wheel- so you can see where you have to grind.
Old Mar 7, 2004 | 08:08 AM
trackbird's Avatar
Jay
I'm not a big fan of grinding on calipers. If you leave any sharp edges, you run the risk of a stress riser that can cause cracking. I'd vote for wheel spacers (I hate wheel spacers) or getting rims that fit. But that's just my opinion.
My thoughts.
Old Mar 7, 2004 | 02:22 PM
I had spacers on the front (no grinding)- but it looked like crap- wheels poked out from under the fenders, so I ground down the fronts too- You are correct though, ou want to make sure to have a smooth radius on the grind- and not have any sharp edges anywhere.
