brakes
Old Aug 24, 2011 | 07:51 PM
blown97ss's Avatar
Default brakes
hello ive been trying to get my brakes to work for a while now with no luck. ok the problem so when i drive the car with the brake booster vacume line on the brakes eventually lock up while driving. ive bleed the brakes a couple of times now and changed out the brake booster and master cylinder out and the problem is still there. if i take the vacume line off the brakes release, any info on what could be wrong.
Old Aug 24, 2011 | 07:53 PM
blown97ss's Avatar
motor is a 383 9:1 comp procharged on 10 lbs i get around 10 lbs of vacume at idle on the boost gage
Old Aug 24, 2011 | 08:08 PM
blown97ss's Avatar
or does anyone with a supercharged lt1 have problems with the brakes that they need to run a vacume pump to the brake booster
Old Aug 29, 2011 | 03:38 PM
blown97ss's Avatar
still have brake problems. forgot to mention i have ls1 front brakes and lt brakes in the back.
