Rear Shock Replacement Help
Old Sep 3, 2011 | 08:50 PM
z2810inch's Avatar
Default Rear Shock Replacement Help
Just put on new set of Bilstein HD's all round, rear end is looser than I expected.
1. How tight / what torque spec should the rear shock top nut be?
2. I have 2 rubber isolators on each one (one inside the car and one outside)...it this right?
Thanks!!
Old Sep 3, 2011 | 09:16 PM
lees02WS6's Avatar
Yes, that correct, on inside, one out. It's 13 ft/lbs or hand tight. If the rubber isolators are beginning to squish they're overtightened.
Old Sep 4, 2011 | 12:37 AM
sjsingle1's Avatar
i tighten til they BEGIN to squish.........then your done
