interchangable rotors?
Old Sep 5, 2011 | 11:35 AM
knightryda01's Avatar
Default interchangable rotors?
Hey guys I was looking to sell my rotors and brand new pads off my 2000 Trans am. I put some ads up and a kid who had a 93 camaro called me. I was assuming they would fit. He seems to not think so. I was under the impression that everything from 93-02 was basically the same as far as the wheels and stuff go. Any help would be appreciated.
Any other vehicles in which are rotors would work on?
Old Sep 5, 2011 | 12:07 PM
94lt1white_bird's Avatar
93-97 brakes are interchangeable with on the 93-97 models and the 98-02 models interchange with 98-02 models....
however that being said cars from 93-97 can do a LS1 style brake upgrade by simply using a spindle assembly from a 98-02 car and use the 98-02 calipers rotors and pads so all the stuff from 98-02 is better ...
Old Sep 5, 2011 | 01:22 PM
Thanks! Appreciate the info!
Old Sep 5, 2011 | 02:16 PM
no problem
your welcome
Old Sep 5, 2011 | 03:04 PM
Badazz 97 TA's Avatar
As long as you use the 98-02 spindles, calipers and rotors then yes you can swap them to a 93-97. You cant just use the 98-02 rotors on a stock 93-97 setup if thats what your asking?
you need to swap everything.
