View Poll Results: Better traction with lca relocation brackets?
I got much better traction/60ft after installing lca relocation brackets!
17
60.71%
They helped with traction a little
10
35.71%
I did not notice a difference in traction :/
1
3.57%
My traction got worse after install lca relo brackets
0
0%
Voters: 28. You may not vote on this poll
People with lca's/lca relocation brackets come in!
i'm at stock height.
i had the stock LCAs and some crappy kumho tires, the wheel hop was pretty scary.
after i put on the LCAs (no relocation brackets yet) the wheel hop drastically went down to where it rarely happened. after i got some good tires on it the wheel hop was completely eliminated. i still plan on putting the relocation brackets on though.
Restricted User
So I got them on today and went out for a test and they hook maybe slightly better, but barelty. It does feel more solid than it did for sure. I think I just got a batch of shitty tires or something. Hopefully I will see a bigger difference this weekend at the track.
The relocation brackets lowered my rear end
So after installing the relocation brackets on my NON lowered car.
I have 4" gap from top of tire to wheel well,
& I have only 1" gap on the rear tires.
All tires are the same size with Koni shocks all around. Solid tube LCA's
I have constant front springs and progressive rears, all stock height.
I have the LCA installed on the lowest hole on the bracket. I do have binding even after re-tightening.
I wonder if I should just take the brackets off.
Just think its weird the rear lowered so much.
LS1Tech Premium Sponsor
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Question is, which spring in the rear can help match my front?
Is there a tall rear spring over stock?
Thanks & sorry for beating a dead horse
I think that since i Went with constant front spring I think they may be taller than stock and causing my front to sit higher.
Can you post pics of how the car sits, and the front and rear suspension so we can see if something stands out being wrong?
