Relocation brackets
Old Oct 9, 2011 | 10:58 PM
fastredlt1's Avatar
Default Relocation brackets
Just put a set of BMR LCA and relocate brackets on my 97 TA. The car is not lowered, I noticed on the brackets that there are two sets of holes for the LCA. What set of holes do I use to bolt the control arms in, upper or lower?
Old Oct 10, 2011 | 12:20 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
top for 'neutral' braking/acceleration,bottom for launch traction.
Old Oct 10, 2011 | 01:11 AM
AndyIsLost's Avatar
I run lower all the time but braking and turning does suffer if only slightly, while greatly increasing straight line traction.
Old Oct 10, 2011 | 07:29 AM
stroked383HSR's Avatar
i use the bottom holes also.
Old Oct 10, 2011 | 09:00 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Indeed. Many people just run them on the lowest setting full time but some complain about binding or a reduction in handling/braking. Give it a shot, if you notice any compromises you dislike, run them higher up and just put them in the lowest setting at the track.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
