switch between 4 channel and sjm abs delete
is there a way to use a sjm abs/line lock kit and still keep access to the regular abs system when i put the regular 17" rears back on? or should i just yank the abs and forget about it?
It's up to you if you want to try to work around your situation. If you feel strongly about having ABS and TCS on your car and the car's braking and wheel selection is not far modified from stock keep it. If you've never felt brake pulsing in your pedal or had TCS go off, you'll never miss ABS and TCS. Normal braking is not affected when you remove ABS/TCS. Actually, you'll have more control over your braking system since you'll now be able to tune the brake bias from the use of the proportioning valve.
Creating a "burnout" for the record is not affected by brake bias. This is what the line lock is for. You shouldn't be applying your brakes overcoming them forcefully. This is how you put unnecessary stress on the driveline, warp rotors and wear your pads.
Hope this helps,
Steve
