Abs ?
Old Nov 10, 2011 | 09:46 AM
ivan c's Avatar
Default Abs ?
I have baer brakes and i want to get rid of my abs.
What do i need to change?
Do i need after market master cylinder with more volume ?
Does wilwood make one ?
Car is 94 trans am
Attached Thumbnails Abs ?-trans-am-029-medium-.jpg   Abs ?-transam-house-006-medium-.jpg   Abs ?-lq9-medium-.jpg
Old Nov 11, 2011 | 10:40 PM
SJMMFGINC's Avatar
Regarding removing ABS, our ABS delete kits will enable you to completely remove the ABS controller AND bracket. Your stock parts will be replaced with new preformed lines, an adjustable proportioning valve and have the ability to either re-use a line lock or install a new one.
Contact Baer regarding changing the master cylinder bore size ...if the caliper design is drastically different, it may be necessary. My guess is they are probably meant to be a direct replacement retaining the majority of the stock brake system.
Old Nov 12, 2011 | 11:50 AM
RARON455's Avatar
I have the SJM kit, worked out great for me.
