Lowering the Camaro
Old Dec 6, 2011 | 05:41 AM
WhiteKnight '01's Avatar
Default Lowering the Camaro
Just had an idea to lower the car. If I wanted to get some lowering springs, who would you recommend I go with, and by how many inches should I lower it?
Is the ride quality really affected that much by lowering the car? And will it handle noticeably better from being lowered? And lastly, will a lowered car reduce how long the shocks will last?
Old Dec 6, 2011 | 07:19 AM
UMI Sales's Avatar
Hey WhiteKnight. Do you have a plan for how much you want to lower your car? One inch vs. slammed takes two different approaches. A balanced spring and shock package with a one inch drop can feel pretty nice yet still give an acceptable increase in handling as lower is faster due to the lower Center of Gravity.
I see you already have Bilsteins. Sam Strano at Stranoparts.com would be your best source for which spring would work with those if you intend to keep them. Balance is key.
As you lower your car, the rear moves side-to-side and can be corrected with an adjustable PHB. Our part http://www.umiperformance.com/catalo...roducts_id=355 is available from Sam as well.
Slammed-low requires heavier spring rates to keep from riding the bump stops all the time and can have an appreciable impact on handling (nice!) with a decrease in ride comfort which some find acceptable, others don't. If you want to go super-low, let us know that as well.
Good luck.
ramey
Old Dec 6, 2011 | 09:11 PM
PGUFF's Avatar
^^I'm with him. Get some strano springs, and you probably will need the adjustable panhard rod.
Old Dec 7, 2011 | 07:48 AM
BMR Tech's Avatar
1"-1.25" is the popular drop on these cars. The lowered center of gravity combined with a revised spring rate can really improve handling significantly when combined with a good set of shocks. It is recommended to replace your shocks when lowering which of course ups the mod cost significantly. Additionally, to do it right, you should install an adjustable panhard rod to keep the rear end centered in the chassis. As you can see what started as a $250 mod has turned into over $1000 mod (unless you put cheap parts store shocks on it). I am not trying to discourage you, just inform you of the overall picture.
Whether you perform the installs yourself will determine if you would want to lower your car in stages. What I see a lot of people do is just install springs for the look then do the shocks/PHR later as they get money and time. This route would cost you more in the long run if you are paying for your installations since they will be doing a portion of the work twice. If your labor is free however, this can easily be done. Just keep in mind however that springs alone will not provide the ride or handling advantages you are looking for. The higher spring rates need better shock valving to realize these performance gains.
Bilsteins and Konis are the popular shock of choice and if you poll the forums you will see that BMR and Strano have the most popular springs. We have spring/shock packages with Tokico, Bilstein, or Koni shocks if you are interested (http://www.bmrsuspension.com/?page=p...d=57&catid=157).
Old Dec 7, 2011 | 07:49 AM
BOBS99SS's Avatar
Captain Double Post
strano or bmr, imo there the only 2 options
Old Dec 7, 2011 | 11:23 AM
VinR1's Avatar
Since BMR blatantly ripped off Sam Strano's springs, it only makes sense to call and do business with the guy that did all the R&D...
Old Dec 7, 2011 | 01:18 PM
Cajun99SS's Avatar
Strano's and bilsteins here. Rides and handles way better then stock. Hell it even hooks better at the track, im still trying to figure that one out.
Old Dec 7, 2011 | 01:41 PM
lethal bird's Avatar
This.
Old Dec 7, 2011 | 02:52 PM
Camaroking1996's Avatar
Go with Strano. Never see any complaints about his springs.
Old Dec 11, 2011 | 12:20 AM
aquariussuperman's Avatar
I have a set of rear Eibach pro kit lowering springs. They lower it a good 1.2-1.4" in the rear. PM me and I can get you some pictures if you are interested. Thanks.
Old Dec 11, 2011 | 12:04 PM
PGUFF's Avatar
Way to contribute. Offer to sale rear springs only instead of offering insight.
Old Dec 14, 2011 | 01:01 PM
^^^ sorry
