lca relocation bracket question..
Old Dec 21, 2011 | 03:27 PM
Ls1_Power25's Avatar
Default lca relocation bracket question..
I just purchased some relocation brackets the other day and they are the bolt on ones but the guy i bought them from didn't give me and hardware to install them. He told me i could use the bolts that are already on the stock brackets on the new relos. Is this true? if not where can i get the hardware to install them?
Old Dec 21, 2011 | 03:36 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Give us a call here at the shop, we have a hardware kit that we send with our bolt-in relocation brackets that should take care of everything you are looking for.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Dec 21, 2011 | 08:40 PM
UMI Performance's Avatar
You can use your stock bolts and grab (2) M12 x 100mm bolts with nuts at a local hardware store, that should do the trick. I hope that helps, Ryan
Old Dec 21, 2011 | 09:55 PM
VinR1's Avatar
No sense in buying a kit and paying shipping too (funny, I was accused of lying when I called asking about missing bolts)
Take Ryan's advice, save money, and get some Grade 8 bolts from the local hardware store
Old Dec 21, 2011 | 10:18 PM
okay guys thanks for all the info. looks like ill be taking a trip to the hardware store tomorrow
Old Dec 22, 2011 | 02:50 PM
NVR_SPDS's Avatar
Look for grade 10.9s or higher in the bolts. The grade 8s will be standard sizes, not metric IIRC.
Grade 8 = Grade 10.9
Grade 5 = Grade 8.8
Old Dec 23, 2011 | 11:59 AM
leadfoot4's Avatar
I bolted and welded mine in place....
Old Dec 30, 2011 | 03:03 AM
Swaie's Avatar
Funny to see the different responses to the ops question...one took the," buy it from us" approach, while the other took the, "here is a quick cheap way to fix your issue." Hmm...there are way more vendors on here than there use to be.
Old Jan 1, 2012 | 08:23 PM
evilz99's Avatar
Was just thinking the same thing. Smh.
