How do you?
Old Dec 31, 2011 | 12:02 PM
2000ESES's Avatar
Default How do you?
how the f@#* do you take off the torx bolt next to the master cylinder to take out the shock?
Old Dec 31, 2011 | 12:13 PM
babbage1109's Avatar
Undo the two bolts to the resivoiur and pull it out slowly and you will have enough room then
Undertow74's Avatar
Haha, thats Funny.
Take out the bolts for the master cylinder, then you can pull the master out and move it over to the side a little bit. Then you can get that bolt out. easy buisness
Old Dec 31, 2011 | 02:35 PM
99zee's Avatar
You can also remove the 2 bolts on the ABS block and pull the entire assembly (MC and ABS block) out of the way. It sounded strange when Sam told me this, but it worked great.
Old Dec 31, 2011 | 04:53 PM
WS.SIX's Avatar
I did this except i loosened it enough to move it out some and angled enough over to slip a bit with a ratcheting flex wrench on it and zipped the stubborn one out
Old Jan 1, 2012 | 02:35 AM
TruBloodTransAm's Avatar
This is what I did as well, worked great!
Old Jan 1, 2012 | 04:31 PM
Orange99Z's Avatar
I put the torx back on the pass. side & the normal bolts on the driver side when I had mine off. Next time I can use a wrench & not have to unbolt the master cyl
