Cutting Springs??
Old Jan 3, 2012 | 02:42 AM
WS6SP33D's Avatar
Question Cutting Springs??
I was just going to order a Eibach pro-kit but i have had a few people throw the ideal of just cutting the stock springs. I have never done this before and was just looking for experienced guys and gals that have cut them, and how many coils to cut? I am running big and littles 27" back tires and i believe the front are somewhere close to 25 1/2" (have to remeasure). Anyway the guy who i purchased the wheels and tires from said he had 1 1/2 coils cut off the backs but he was running coil-overs on the front. My question is if i take 1 1/2 coils off the rears would i need to take 1 coil off the front? (i dont wont the rake look) If anyone has any advice or pics plz post up pics and give the details. Thanks in advance.
Old Jan 3, 2012 | 11:48 AM
Turbodude06's Avatar
1&1/2 coils is a lot. Most people start with a half coil at a time. I love cut springs cause they ride like stock, or you can torch them too that works good.
Old Jan 3, 2012 | 02:41 PM
blackjack325's Avatar
dont do it, get an engineered package. the correct amount of drop from the spring with shocks to match the drop. otherwise it'll ride like crap.
dont cheap out. IMO
Old Jan 3, 2012 | 02:50 PM
MasterTomos's Avatar
Ive never experienced good ride with cut springs, thats the cheapo way to do it. They dont perform correctly and ride like ****...
Get some that are correctly engineered.
Old Jan 3, 2012 | 09:18 PM
Latch's Avatar
I wouldn't go more than a full coil, otherwise the car will be too low and will hit the bumpstops constantly. I've got a full coil cut and the ride is great, it's actually better than stock since I replaced the DeCarbons with Bilsteins, and the stance is perfect - not slammed, but no longer 4x4 status.
Old Jan 4, 2012 | 01:47 AM
WS6SP33D's Avatar
Thanks for info guys. Latch did you take 1 coil from front and rear? I'm running AGX 8 way adj shocks. Thanks again
Old Jan 4, 2012 | 09:37 AM
RevGTO's Avatar
Pontiacerator
Don't listen to the naysayers. 1 coil = 1 inch roughly. Like Latch said the ride & handling will be fine and you'll have the look you want.
Old Jan 4, 2012 | 09:42 AM
ISMELLRICE's Avatar
i did 1 coil and after it settled it looked almost the same as my eibach sportlines...
if you are doing it dont do more than 1/2 coil...
fwiw my car rode like ****
Old Jan 4, 2012 | 11:45 AM
Latch's Avatar
Yes 1 coil front and rear, also did the heater hose mod... my car was way too high up in the rear before lowering it so this way it ended up damn near perfectly even.
That's odd, my car sits significantly higher than a car on Sportlines. And as far as it riding like ****, what shocks did you have?
Old Jan 4, 2012 | 06:29 PM
NBM99SS's Avatar
That's odd. Mine barely rides much more harsh than stock and its nowhere near slammed like sportlines.
Old Jan 5, 2012 | 10:16 AM
turbopalmen's Avatar
Do you mean the very first coil that makes the spring stand straight
or didn`t you count that coil?
Where did you cut? like the left or like the right?
Old Jan 5, 2012 | 10:30 AM
WS6SP33D's Avatar
^^^ This. That is the same question i was planning on asking Latch.
Old Jan 5, 2012 | 10:56 PM
RevGTO's Avatar
Pontiacerator
1/2 a coil is 180* from the tip (end) of the spring, 1 coil = 360*, etc. You cut the non-pigtail end (top).
Old Jan 6, 2012 | 02:41 AM
but when you look at the spring you realize that the first coil 360 from the end can`t drop the car 2" like they say that 1coil does?
i think they don`t count the first coil because ìt`s "flat"
why can`t anyone that have cut ta springs before answer??
Old Jan 6, 2012 | 04:56 AM
BOBS99SS's Avatar
Captain Double Post
im with these guys, have been in a car with cut springs and honest it didnt feel any diff than stock, couldnt tell you how much was cut but it couldnt of been that much, i say op go for it, maybe you will like it and save some money
Old Jan 6, 2012 | 08:28 AM
ryany's Avatar
I cut mine like where you have marked on the left side and did the heater hose mod and it gave it a good stance.
Old Jan 6, 2012 | 10:07 AM
WS6SP33D's Avatar
Any pics? Thanks for your response. So if you cut it like the right pic and left in the isolator that would give you 1/2" more drop..
Old Jan 6, 2012 | 05:30 PM
ryany's Avatar
Well I have 28'' Hoosier Radials on back of my car and when i cut the springs it gave it a nice stance. I would do it in like halfs you dont wanna cut to much because its going to settle when you start driving the car around..
Old Jan 7, 2012 | 09:21 AM
Now i have cut my springs.
i cut 2 coils in front and 1,5 coil in the back. I think it`s almost like sportlines.
I have 20" rims and i`m satisfied with the drop in the front but going to do hose mod to in the back. The suspension is very stiff in the front...but looks is everything
Old Jan 7, 2012 | 09:41 AM
Latch's Avatar
^ I thought those houses looked a little strange then I noticed this guy's in Sweden! Sure is cool to see an F-body in that part of the world.
