fixes for lean in front?
Before you cut the spring try cutting the drivers side end-link about 1/2" shorter(center section spacer), or buy a shorter one (-1/2") for the drivers side, or longer one ( +1/2")passenger side.
If you re-use the same end-link bolt then I'd just stack 1/2" of washers under the nut and tighten it down with the same length of exposed thread above the nut. This way will be easier because of the longer bolt, with a new shorted bolt getting the nut installed on the bolt will be more difficult. I'd also wouldn't tighten down the nuts until you have both nuts loosely threaded on the end-links, and if you use the shorter bolt tighten it down the same.
Well got the new endlinks installed today at work. With no washers factory size it dropped down about 1/4 inch. Installed some washers right below the nut on top and stayed the same. If I can get another 1/4 to 1/2 ill be completely satisfied. Got any more suggestions? I still have to reseat the pigtails on rear springs or reinstall the isolators because they settled and its way to low in the rear. Even lower than the front.
I'd reinstall the rear isolators if it's to low.
Update: thanks alot to 99Bluz28 first off. After reinstalling new end links properly and raising the rear up a little with the rubber isolators I am now sitting less than 1/4 inch difference in the front. The rear looks much better too giving me a very slight rake instead of sagging below the front. the front driver is right about 26 1/4, passenger is 26
driver rear and passenger are right at 27 inches. Props to you Blu for all the advice and everyone else as well. Hope this helps someone out there with there abnormally leaning car lol
So... this is with the driver side EL spacer 1" shorter, or at the previous 1/2" shorter?
