TH400 Crossmember ?
Old Jan 3, 2012 | 01:33 PM
oChristiano's Avatar
Default TH400 Crossmember ?
I have a LS swapped LT1 Z28 so obviously I need the cross member for a LT1 car but with a TH400 still match up to it behind a LS since a LS sits about 3/4 an inch back farther? I had to slot the holes in my stock LT1 Crossmember to bolt up the 4L60E. Anyone do this before? Was looking at UMI Cross members, just preference.
Old Jan 3, 2012 | 02:19 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
I take it you did not perform the swap with a K-Member? It could create some difficulty in selecting the correct crossmember. The best solution is to measure the distance from the 4L60E mounting location and then it would be easier to see which part would fit the trans the closest. It may not end up being the correct one, but we can modify it to make it fit.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jan 3, 2012 | 03:43 PM
UMI Sales's Avatar
Good afternoon.
Did you use our LS k-member? Can you give us a call tomorrow to discuss?
thanks
ramey
Old Jan 4, 2012 | 10:57 PM
Yes I used a LS1 K member to do my swap as I used a 01 ss donor car. I'll give you a call tomorrow to discuss. Im just planning out the swap at the moment and seeing what is needed before I buy a cross member just to figure out it wont work.
