Best Grease?
Old Jan 20, 2012 | 11:22 AM
LS1121's Avatar
Question Best Grease?
I'm going to be replacing my shocks soon and while I'm in there i want to re-grease my poly Bushings, the Red ones. I know I can buy more of the grease that came with my kit from Summit, but what is the Best grease to use on these bushings?
Old Jan 20, 2012 | 11:24 AM
metalmilitia606's Avatar
I was always told white lithium grease is good to use. I put that stuff in my roto joints and it keeps them quiet.
Old Jan 20, 2012 | 12:04 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Don't use a Lithium based grease on poly-urethane bushings, it will make them soft and lead to deterioration of the bushing. We recommend a grease called Super Lube which we sell and can also be found at your local hardware store sometimes. It is a thick, clear, and very sticky grease that doesn't break down as fast as some of the other greases out there. If you can't find that stuff Mobil 1 synthetic is also pretty good to use.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 20, 2012 | 04:01 PM
LS1121's Avatar
Thanx for the reply, i will look for it.
Old Jan 20, 2012 | 04:37 PM
BMR Tech2's Avatar
No problem. You'll be able to find the Mobil 1 pink goodness at most major auto parts stores, but the Super Lube will be a little harder to find but tends to hold up a little longer.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
