Full Polyurethane Bushing Kit??
The rear tires are 17 inch 285's Nitto555r in the rear. BFGoodrich 275's up front
I had no idea poly was such an issue with our stock suspension setup. I am glad the lca's are the only poly on the car at least. Where is a good place to buy new rubber bushings for other suspension part?
I'm kinda pissed about not getting roto lca's. I just bought the poly ended lca's recently too. Looks like I might as well buy some relo brackets now.
Anyone need or know anyone that may need any poly lca's for cheap? lol
What should I use out of the kit?
I was planning on torque arm mount, sway bar bushings, and end links. Is there anything else I could use?
Now that I read about "bind" and all that other bad stuff, I'm perfectly happy not using some of the components from the kit.
My stock rubber isn't bad, but some parts of the car feel pretty loose. I'm getting Bilsteins next week.
My car has a bone stock suspension with the DeCarbon shocks.
As far as changing the bushings on the LCA's, I am not 100% sure. A quick call to UMI would clear up any questions you have in no time. Customer service is great.
If it isn't possible to change the bushings, just post them in the classifieds section. I would imagine they will sell fairly quickly at a fair price. I would do this anyways, and just purchase yourself a set of LCA's with roto joints.
The second one was just a flogger. I was at a point in my life where I didn't mind working on the top of the engine but anything underneath or suspension related, other than brakes, I'd take to a nice shop I found. I had the shop install poly bushings all around including engine mounts, it cost about $1000 which included the bushing kit (if I buy their marked up parts then I get a one year warranty on their work). I was debating doing this because I read about some people's bad experiences, but since it was just a flogger, I decided to try it out. I had already received a remarkable handling increase from some expensive shocks/struts, tires, and coils.
The shop did a great job of installing them. As I expected, the suspension was about as forgiving as a brick, but I did notice an increase in cornering capability. I was happy. Maybe I didn't put enough miles on them or who knows, but I never had any binding problems or broken suspension parts.
HOWEVER due to the extra vibration from the stiffness, other things on the car that were not in the best shape started to cause problems. Electrical wiring that was next to metal or sharp plastic rubbed up against it harder, cutting and baring wires. This only happened twice but electrical problems can be absolutely horrible to track down. Some of the clips holding interior panels in place broke and I had trim fall down while driving around. Minor annoyances if it's not an every day drivet.
Now im on my third one, and I'm not going to go with poly bushings this time around. It's still a flogger but I'm going to try something different, even if it costs more.
Life lessons: if it's a daily driver and you don't have the money to fix it whenever it breaks, maybe just use OEM bushings and go about improving your suspension in other ways. If it's just a fun flogger and you can throw money/time at it or let it sit for a while if it breaks, plus you don't mind riding on a brick-solid suspension (I actually liked the feeling) then yeah sure go with the poly bushings, grease them well or have a good shop install them.
