Bad ball joint?
Are the ripped ball joints the indication for replacement? And what are the dangers?
Aight thanks man. Ima do that. I didn't know it was so easy to check for a bad ball joint
.To replace the boot do I have take off the ball joint?
its just one of them things you dont take off, and put back on, used.
I haven't done it, but Ima do it today?
Ok so I fount out that is not the ball joint, it is the tie rod boot correct the one with the long stick?
Anyways since Ima buy new tires, do you guys think they will change it for me while they align the wheels and install the tire or is it hard to change the boots on these tie rod?
Ripped boot is no big deal, ride em till they go bad. If you're going to take stuff apart just to replace a boot you'd better just replace the part while you're in there, everything is very cheap on the front end, save for the Moog stuff which is top of the line.
They probably won't change the boot for free when aligning the car. For an alignment all they have to do is bust the jam nut loose on the tie rod and turn it to make the proper adjustment. To replace the boot/rod you would need to disconnect the tie rod. It would take you 10 minutes to do it yourself.
Alignments are such a rip off for the amount of work vs. cost. They literally just get the car up on the lift, connect the sensors, bust 1 nut loose and give the tie rod a turn. Tighten the nut and done. I used to do alignments in 15 minutes.
Ima be honest my tools are very minimal. If they do not charge too much I will tell them to do it as well. I hope they give me a discount since I am buying tires. I have a feeling this is the reason why my car vibrates badly at 70+ HW speeds. thanks Bro. Now Ima do the test like you told me to check for myself if the tie rods are good. Thanks
. Question once I lift up the car and remove the wheel all I have to remove is that pin and nut. Then I replace them with a new set and get an alignment right?
Use an open end or crescent wrench to hold shank of the tie rod, and use the same to break the jamb nut free, then unscrew the tie rod end. it's recommended to use a new jamb nut, and most good rod ends come with a new one. Mark where your current nut is, remove it, and screw on the new one to the same spot, then screw on the tire rod end and tighten every thing up. This should be close enough so you can drive to the alignment shop.
. THANKS ALOT
.Im going for it, I wil be putting moog I heard thats the best tie rods you can put.
