Fays 2 setup
Old Mar 17, 2012 | 07:45 AM
Wile E's 98's Avatar
Default Fays 2 setup
I got all my parts in and want install them all his weekend while i have the car jacked up. I just got the basics like SFCs, LCAs and the 3in dual set up from TSP. I also got the Fays2 watts link set up. It didnt come with instructions or a set up sheet. I called Jim and he said he send me some but I want to get done this weekend if possible. So I was wondering if anyone has any pics of theres or some advice on how to adjust it.
Old Mar 17, 2012 | 08:29 AM
lees02WS6's Avatar
I have the instructions in PDF form. I can't attach it here as it's too large (ls1tech limits PDF's to 342k). PM me your e-mail address.
Old Mar 17, 2012 | 08:45 AM
My e-mail is on the fritz. Im going to see if i can get it fixed in a min. If i do I will definitely pm.
Old Mar 17, 2012 | 08:53 AM
lees02WS6's Avatar
Try this link
GM GEN 3 & 4 F-Body OWNER’ S INFORMATION and INSTALLATION INSTRUCTIONS 2009
Old Mar 17, 2012 | 09:18 AM
lees02WS6's Avatar
Good luck with the install, post up some pics. If you have a gopro drive it around and take some motion shots, I'm sure a lot of people are curious about it.
Old Mar 17, 2012 | 09:25 AM
Hey that will work, answerd my questions. Thanks.
Old Mar 18, 2012 | 10:46 PM
TruBloodTransAm's Avatar
Hardest part for me was to grind off those brake clips. Also helps if you have a drive on lift.
Old Mar 20, 2012 | 01:32 PM
I got it installed with no problems. Works awsome! I still have the crappy factory shocks. Still has the factory bushing and ball joints as far as I can tell. I drive on a lot of windy country roads and be fore the car was unpredictable. It seemed like in the middle of turn when the body leaned a little the car would steer more or less. Very unconforatble feeling when doing 65 or 70 on a two lane road. Now, even with the worn out parts, it goes right where I point it and stays on line, very controlable. I would recomend one for anybody that drives in anything other than a straight line. I cant wailt to put on some shocks and upgrade the breaks. I m ready to try some autocrossing, hopefully by the time LS fest roles around. I also put on SFCs and tubular LCAs at the same time.
Old Mar 23, 2012 | 04:54 PM
LS1HIGHLIFE's Avatar
Post up some pics! I'm waiting on mine to come in next week. I can't wait to install it and go for a spin.
Old Mar 23, 2012 | 07:49 PM
libertyforall1776's Avatar
So once you guys set your Watts Link and dial-it-in -- is it pretty much set it and forget it, or is it something you need to regularly check/adjust? TIA.
Old Mar 23, 2012 | 10:04 PM
peterlawl84's Avatar
I just set mine and no further adjustments. Now, like with all the adj. stuff, you should regularly check to make sure none of the nuts have back off.
