Time For new SHOCKS?
http://youtu.be/GXNsNNtfXEE
When you drive around - how does it feel?
That being said, the stock decarbons are crap and should be replaced as soon as you can afford them.
Shocks are as usual: you get what you pay for.
Bilsteins are a good for the budget.
Konis are good for performance.
Also no neighbors within eyesight not that I care anyway, hell I've adjusted coilovers in the walmart parking lot I don't give damn what people think, I do what I gotta do to get my point across.
I would be looking at springs for atleast the rear simply because it sits way to high to me, but i'm in a similar situation with my driveway that I would need to really look at before diving that far in, its one of the main reasons I got rid of my last car, that damn thing was just 2 low for where I ended up having to drive everyday.
I doubt it's the wiring, but they say the wiring doesn't supply enough volts so it puts wear on the motor. They sell a rewire kit so it gets direct power from the battery so it doesn't put wear and tear on the motor. The Best V8 Stories One Small Block at Time
I doubt it's the wiring, but they say the wiring doesn't supply enough volts so it puts wear on the motor. They sell a rewire kit so it gets direct power from the battery so it doesn't put wear and tear on the motor.By the way this car was sitting on Koni sport yellows, ground control coilovers (which have eibach springs) and a full SPC performance camber kit. That car in the shot with the 18's would align to perfect factory spec, getting it on and off the alignment rack was a whole nother story. but for about 1300 total in parts for the whole suspension it kicked ***.
Save up your money and do it once.
The travel has nothing to do with the shock, thats all the springs. The shocks control how quickly the springs compress and rebound. The "push on the bumper" test really only shows so much (if anything at all).
A good budget shock that rides smooth and works well with lowering springs are Koni SA's, or even higher end shocks. The rest either don't ride smooth, or don't work well with lowering springs (at least not nearly as well) or both.
As is pretty normal, JD has learned this stuff well and given spot on advice.
Do you need new shocks? I'm 100.5% sure you do since I get the impression they are just old stock ones. But only do that if you want the car to pretty much do everything better, ride, handle, and deal with bumps and impacts too.
As for lowering springs. You need to decide if you want to lower the car, that's the first thing to do. Your car isn't sky high, and the best ride quality will come from stock springs and excellent shocks. It's a matter of real world thinking. Stiffer lower springs don't do a lot to enhance suspension travel range, or the ability for the wheel to move up and over a bump when you hit it. That's why lowering springs are best teamed with the BEST shocks you can muster... because you are demanding a lot from the damper with the higher rate and shorter travel.
