Reduce 60ft
Old Apr 19, 2012 | 09:02 AM
cory32690's Avatar
Yea there spinning for sure and inonly stalled it to 2600-2800
Old Apr 19, 2012 | 09:05 AM
cory32690's Avatar
If there above 20psi at all I can't get better than a 2.0-2.2 60ft
I think the stall and the control arms being on lowest spot is shocking the tire
Old Apr 19, 2012 | 11:05 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Have you tried modulating the throttle? What I mean is rolling into WOT off your stall. When I would drag race on 17-inch Nitto drag radials I would pull myself through the second set of lights with the stall and back it down a little, then when the tree dropped, I would roll into the throttle so the car would maintain traction all the way through. I was able to get some very good 60-foots this way. I would try that out because Nittos aren't the best track tire.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Apr 20, 2012 | 04:10 AM
cory32690's Avatar
Thanks I haven't tried that one..I'll give that a shot are local tracks open tonight I might go see what I can get
Old Apr 20, 2012 | 08:01 AM
BMR Sales2's Avatar
Like Kevin said flashing the converter off the line may work a little better then stalling it up but I think a better set of tires is going to end up being your fix. Let us know how it runs at the track.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Apr 20, 2012 | 05:45 PM
cory32690's Avatar
Will do..
Old Apr 20, 2012 | 11:26 PM
JKB315's Avatar
I went tonight. My two best 60 foots of the night were 1.74 and 1.75. The rest were horrible. My track has a rep of bad prep though . I am getting some m/t soon . I also lost 1-2 mph and all I did was out a new idler pulley on. Weird.
Old Apr 21, 2012 | 04:12 PM
cory32690's Avatar
Track got Rained out Friday I didn't get to go..I'll have to wait till next week
Old Apr 24, 2012 | 11:09 PM
UsmcAlston's Avatar
FTI 4000k Stall
615/598 232/240 114+2 lsa
17in Mickey Thompson ET Street Radials
Flashing on the convertor spins, stalling to 1500 spins
coasting out to 5mph and hitting it spins
best 60ft of 2.2
car won't hook
no suspension
got Qa1 coilovers coming
bmr panhard
need a torque arm and lcd with relocating brackets
Old May 19, 2012 | 10:36 PM
JKB315's Avatar
I can't do better than a 1.74. Mostly 1.77, 1.76 and so on. A few 1.80s. I did 7.95 @ 86.70 Car hooks great now with ET streets. I put in 50/50 comp rears and removed the front sway bar. Should I be happy with this? Or can a relatively stock motor do better? It's a 3600 stall with 3:73s. It even still has exhaust manifolds on it till next week.
Old May 21, 2012 | 08:27 AM
BMR Sales2's Avatar
Honestly that isn't too bad, you really need to some more power to go any faster than that. Once you get some more power you will definitely see those 60ft times drop, there is just only so much you can do with roughly 300 horsepower to the tires.
__________________
Glenn ***
Sales Tech
813.986.9302
Old May 21, 2012 | 08:53 AM
  #32
UMI Sales's Avatar
^^ What Kyle said. Are you 100% dead hooking now? If you're hooking well enough to bog the motor it's time for more HP!
Old May 21, 2012 | 09:31 AM
  #33
JKB315's Avatar
Yeah it seems to be hooking well. I hear a occasional chirp when I launch. On the 1.77 run my s60 hit the floor. Looks like I need to clearance it a little. Can t wait to get my longtubes on to see if I can squeeze another tenth out. It felt good to embarrass a few new 5.0s at the track. They were running sticky tires so not sure what their excuse was.
Old May 21, 2012 | 09:59 AM
  #34
BMR Sales2's Avatar
Once you start adding some go fast goodies to the car you should see some better 60ft times and E.T.s. Keep us updated once you get back to the track with more power.
__________________
Glenn ***
Sales Tech
813.986.9302
Old May 21, 2012 | 11:20 AM
  #35
JKB315's Avatar
Will do. I am still working on weight reduction in the meantime while I save up for more parts. I need to get it weighed to see where I am now. A guess would be 3400. After headers I was entertaining a 100 hp shot to see where it would put me.
Old May 21, 2012 | 11:45 AM
  #36
blackblurr_00gt's Avatar
iv been reading this post and maybe someone can tell me what im doing wrong when my car was stock with just lid lts and xipe with a yank pt 4k stall i was dead hooking on et streets and cutting 1.65 60fts im heads and cam now and still dead hooking and can only get a 1.75 to 1.78 60ft iv tried stalling up and just flash stalling the converter. my car befor the heads and cam was doing 12.1 to 12.0 and its only doing 11.7 to 11.6 wherew am i screwing up at. also im launching on 26x10.5x16 MT slicks now cause thats all i have.
stock lowers control arms that have been boxed and stock torq arm.
Old May 21, 2012 | 11:52 AM
  #37
UMI Sales's Avatar
Headers and a shot might just do it!
Old May 21, 2012 | 01:05 PM
  #38
JKB315's Avatar
I am no expert but I would think the extra power is making that stock torque arm flex. A body mounted one will prob help a lot and your tail shaft will thank you.
Old May 21, 2012 | 06:21 PM
  #39
^^^ thnx.
oh and my mods are
lid
pacesetters
xpipe
handported 241s
tsp tsunami camshaft
pt 4k stall
3.42 rear end from a 6speed car
fast 92 with 92 mm tb
the car made 422hp and 380tq with a ls6 intake
then it made 432hp and still 380tq with the fast 92
these are coverter locked numbers
unlocked car is putting 409 hp to the ground
my first guess was the tune but i had it retuned after the fast 92 install and it is running even better now i just cant figure out what else i need or should do.
Old May 21, 2012 | 06:42 PM
  #40
UMI Sales's Avatar
http://www.umiperformance.com/catalo...ex&cPath=7_115
Bulletproof, strong, solid torque arms!
ramey
