Line Lock Switch in Ashtray
Old Mar 27, 2004 | 11:20 AM
Rockit_GTO's Avatar
Default Line Lock Switch in Ashtray
I mounted my line lock switch in my ashtray. Where should I connect the ground wire?
Thanks
Old Mar 27, 2004 | 12:56 PM
slow's Avatar
not to the ABS controller.
On the M6's i just connnect the grounds to teh shift boot ring. im sure the A4's have some kind of ground in teh console.
if you can't find a good one there, the side of the console has 2 10mm bolts, you can connect to there.
Ryan
Old Mar 27, 2004 | 05:30 PM
Tranzor's Avatar
Can you take some pics of the setup, specifically on how you drilled/installed the switch into the ashtray? I'd like to install mine there...
Old Mar 31, 2004 | 08:11 AM
02 WS-6's Avatar
Do you need a line lock for each side with ABS setup? I'm fixing to do one, and was currious.
Old Mar 31, 2004 | 09:10 AM
SJM Manufacturing Inc's Avatar
You only need one solenoid for a line lock. Components can be easily mounted in the ashtray by drilling a hole with the size needed for the switch...just be certain the switch is small enough so that it fits:-). A ground wire should be easily found in the console...verify with a multimeter if your uncertain...any part of the chasis is ground also...just be certain to clean off the painted surface before attaching a wire.
We add a safety circuit on all our kits which include a master arm switch and LED so you know the circuit is active thus not accidently arming the solenoid and causing an accident or burning out the solenoid from leaving it on more greater then 60 seconds.
Attached is one way one of our customers put our kit on their center console...there are various ways of doing it. Our complete "best buy" kit with pre-formed lines and electrical needs is 114.99 SHIPPED.
Hope this helps some.
Steve
Old Mar 31, 2004 | 09:16 AM
file doesn't seem to want to attach after this mornings software upgrade..i'll try again.
***edit** if anyone can see the attachment let me know as I don't see it, although when i'm trying to edit this post to be certain the file is attached, it most certainly is.
Steve
Old Mar 31, 2004 | 03:15 PM
THECowboy's Avatar
BAHAAA, i have figured it out!!! to see the new attachments AFTER the forum you need to be in the NEW(plasma) board setting!!!!!
