Differences in R&P from 98 to 02?
Old May 28, 2012 | 12:32 PM
Blwn_by_Twins's Avatar
Default Differences in R&P from 98 to 02?
I have replaced my R&P in my 98 TA a couple of times using the shitty Fenco rebuilt one. Well I've had enough and am getting a AC Delco rebuilt one. After looking at some part numbers I noticed that I put a rack from a 02 in my T/A last time, part number RP6562 and it calls for a RP6537 for a 98. Although it didn't last 5000 miles, the RP6562 (02 R&P) worked just fine. So my question is what is the actual difference in the two? Even the AC Delco shows a different part number for the years. I'm not talking about the code differences either. Both FE2-4 in separate years have different part numbers. I plan on getting the AC Delco one for the 98 b/c it is actually cheaper. So does anyone actually know what the difference is?
Old May 30, 2012 | 09:30 AM
Anyone know?
Old Jun 1, 2012 | 05:53 PM
chrysler kid's Avatar
What is an r&p ?
Old Jun 1, 2012 | 06:02 PM
whytryz28's Avatar
Originally Posted by chrysler kid
What is an r&p ?
Haha this. Maybe rack and pinion? If so the ls1 models are all the same.
If you have some special HD suspension(FE2, FE4, FE7, F41) then it gives a different R&P number only 2000-2002 models have it though.
Old Jun 1, 2012 | 07:11 PM
trans_am7935's Avatar
the F41 and the FE2 are different angles on the input shaft for the Rack and Pinion. but i didnt think they were different from year to year.
Old Jun 1, 2012 | 10:24 PM
whytryz28's Avatar
All the HD suspensions got the same rack from 00'-02' its kinda weird how GM set it up.
Old Jun 2, 2012 | 02:58 PM
Just kind of strange that the same rack would have 2 different part numbers, and one be a good amount cheaper. My AC Delco one (part # for the 98) will be here Tues and I'll report back if I have any problems.
Old Jul 10, 2012 | 07:55 PM
Go it, installed it, 0 problems. So I guess either will work. Might as well get the cheaper one. lol
