Installed 5th gen Brembo's on my '02 Camaro
Wow, nice.
I just got CTS-V calipers in I ordered from my dealership today.
I was going to go 18s, but might go 17s since they fit.
Did you use stock brake lines? Did the stock caliper bracket bolts not fit?
You say 5th gen front wheels but I thought the lug pattern was different, I know it uses 14mm studs at least.
#40
idk, only one way to find out. i am gonna order the calipers, and install them in place with no rotors (not required for fitment) and see where to go from there.
my only issue is that i my wheels when they were ballanced, have the stick on weighs right on the inside lip of the wheels, so they will need to be re-balanced cause i will be removing the stick on weights.
