Problem: Brake issue
Old May 30, 2012 | 12:09 PM
LS1SSZ28's Avatar
Default Problem: Brake issue
Recently i went over a pot hole and since then my ASR OFF light, BRAKE Light and ABS INOP light has been on.
No codes are being read, so i didnt know where to begin.
Any Ideas?
Old May 30, 2012 | 07:37 PM
LS1SSZ28's Avatar
Ive checked all the fuses, Im lost... any ideas?
Old May 30, 2012 | 09:38 PM
massls1guy's Avatar
Maybe a bad wheel sensor or wiring to the sensor. You can use an ohm meter to check it. Look at post #13 in this thread:
https://ls1tech.com/forums/suspensio...-welcomed.html
Old May 31, 2012 | 06:01 AM
wssix99's Avatar
Save the manuals!
The codes are there, stored in the ABS system. You will need a special scanner to read them.
Old May 31, 2012 | 09:09 PM
LS1SSZ28's Avatar
Just checked the speed sensors and the wires on my front passenger sensor were unplugged. Problem is the pigtail connector that plugs into the speed sensor was loose for a while and was grinded down by the rotor... I need to replace it
BUT can not find the wire to replace it to save my life. Anyone know where to find it?
Old May 31, 2012 | 09:48 PM
massls1guy's Avatar
This might be it, see if it matches the connector on the other wheel:
http://www.ebay.com/itm/GM-ABS-WHEEL...item43a9adcacf
Old May 31, 2012 | 09:52 PM
LS1SSZ28's Avatar
This is the correct one for plugging into the main harness but I need the one on the wheel side which looks different. Cannot find it anywhere!
Old Jun 3, 2012 | 08:31 AM
ryangtp89's Avatar
I'm having the same issue. This happend soon after my front calipers on both sides came off, bolt snaped and the others dissapeared. I had my brothers friend who "use" to work at a small shop but on my new rotors and pads and it needed new calipers up front because they were sticking i guess anyways i'm getting all of those lights. im guessing a speed sensor wire ? i just have been too lazy to check, it doesnt really bother me. I actually got to replace one of my brand new c6 wheels because the caliper dug into the wheel soo bad it put holes and i had it welded and it didnt work still a slow leak.
