E-brake, abs light
The other day I had my p/s pulley break and take my serpentine belt with it, a buddy came and picked me up and we towed the car home. When we got the car home I noticed what I think is the speed sensor for the rearend came unplugged, I got under there and plugged it back in nothing else was loose. The next day I go to school and halfway down my street I look up and my handbrake light is on like I still have it pulled up. After getting to school I try some experiments.
If I start the car and let the handbrake down the brake light turns off and stays off, once I start driving, maybe 15-20 seconds after pulling out of a parking spot my brake light turns back on and stays on for good until I shut the car off.
Help please, I have an idea that the headers might be burning something and causing my abs light to come on but I have no idea where the brake light came from.
The brake light could be a dirty e-bake switch. If you unplug the switch, jump the wires, and the light goes off - you just need to clean/polish the switch.
That brake light can also mean a general system failure. Since you just had an "explosive event" near the brake system, I'd suggest testing it to make sure that its just the switch before you drive again. It may also be worth while to check your brake fluid level for kicks.
wssix99....its called "a major investment" had a laugh at that one.
I hope this helps you and if you have any questions, just put em out there and I am sure these guys will be able to help you.
