Do Hal Shocks Need any Modifications??
Old Apr 8, 2004 | 07:42 PM
SS GIRL's Avatar
Default Do Hal Shocks Need any Modifications??
Do the front ones need any modifications? or do they fit right on?
thanks a ton
Old Apr 8, 2004 | 07:50 PM
C54U2NV's Avatar
IM pretty sure they will fit no prob.
Old Apr 8, 2004 | 08:02 PM
95_Firehawk_Dude's Avatar
They fit right in
Old Apr 8, 2004 | 08:47 PM
SS GIRL's Avatar
thank you much.....
Old Apr 9, 2004 | 08:41 AM
NHRATA01's Avatar
Well, it depends what you're doing. If you want to use the stock springs with them, you will need to buy or make modified stock spring seats.
Other than that, they should be good to go. One thing to remember when putting the upper mount on the shock, is to mark it in relation to the center of the lower mount of the shock. This way when you go to put the shock on the car, the 4 holes on the top mount will align correctly with the 2 holes from the bottom mount. Once the spring is on you can't really rotate the top or bottom too much if the mounting holes don't line up - the spring just has too much force, and you'll have to copress it again if anything needs to be adjusted.
