Changing brake lines
I am getting ready to install new pads and rebuild the Corvette calipers, and I am going to change the front brake lines to braided stainless C5 lines, since the stock TA lines were a little tight when I did the conversion. They work fine but are just a shade short when the wheel is fully turned. The C5 lines are a little longer so I'm just taking this opportunity to get rid of the stock TA lines and fix this potential problem.
Is there any way to change the lines without running the ABS dry? I have a Mity-Vac hand pumping solo brake bleeder. Will this pull the fluid through the ABS module? When I changed the rear pads recently I used the tool to bleed the brakes by myself and I also changed out all the old amber fluid and replaced it with DOT 4 blue, so it seemed that the fluid was pulled through the ABS.
I have a well equiped garage to work in but the car is my daily driver and can be down for a maximum of 3 days, so I'm trying to plan ahead to avoid unexpected problems. I will be doing the work alone.
Am I opening a big can of worms if the ABS runs out of fluid? Will the vac tool pull fluid through?
Any input is welcome.
To give you an idea that it is not that big of a deal with the ABS. I used a turkey baster and sucked all of the fluid out of the reservoir, installed a line lock, changed all six lines. Once that was complete I was able to bleed the system/tighten any weeping lines in about 30 minutes or so. I did have a second person to help though.
