lowered with 315s
Old Oct 30, 2012 | 05:09 PM
unioncarpenter84's Avatar
Default lowered with 315s
what lowering kit besides coil overs could i get away with using 315s on tt2s on a 94 camaro
i need the 315s because the 10.5 rims but want the lowered look
whats a good spring to go with
Old Oct 30, 2012 | 05:24 PM
anyones recommendation
Old Oct 30, 2012 | 05:31 PM
Sam Strano's Avatar
LS1TECH Sponsor
I'd say mine. PM answered about your tires and wheels. My springs are proven and it seems we've talked before too.
__________________
Old Oct 30, 2012 | 05:35 PM
Ellsworth's Avatar
I have BMR 1.5" lowering kit, with 10.5" rear wheels on a 315/30/18 and they don't rub or anything, all I did was chop off the bumpstops, and beat the inner fender well in with a mallet.
Old Oct 30, 2012 | 05:37 PM
any issue with rolling fenders?
looks goood
Old Oct 30, 2012 | 05:38 PM
yes we did....thanks alot
Old Oct 30, 2012 | 06:51 PM
Ellsworth's Avatar
no rolled fenders
Old Oct 30, 2012 | 07:35 PM
1994_383_Z28's Avatar
Stranos for sure. I have 315s on an 11in wide rim, lowered on stranos, without rolling the fenders. No rubbing.
Old Oct 30, 2012 | 07:53 PM
is strano and bmr the same?
is it okay to use factory new shocks or the kyb non adjustable
Old Oct 30, 2012 | 09:39 PM
Storm Trooper's Avatar
Don't go with BMR, I have stranos and they are by far the best springs out there, great handling and surprisingly smooth ride compared to eibach, hotchkis, and bmr, Sam is a great guy to deal with and you won't be disappointed. I have his springs with Bilstein shocks and 11" wide CCW Classics with 315s, no rubbing at all!
Old Oct 30, 2012 | 09:47 PM
HCI2000SS's Avatar
I'm just curious what makes the Strano springs that much better than the BMR ones? I only ask because i'll be choosing one of these two soon
Old Oct 30, 2012 | 09:53 PM
I felt an improvement in handling and the ride is much smoother than I thought it would be on the stranos, not to mention they are tried and proven to be some of the best on the track and auto-x. As far as spring rates and the technical side of it, I'm not to knowledgable, perhaps Sam could tell you more about it.
Old Oct 30, 2012 | 09:57 PM
HCI2000SS's Avatar
Okay cool, thanks man!
Old Oct 30, 2012 | 09:59 PM
No problem, I am not bashing on BMR, they still make pretty good springs, especially compared to eibach! Just my .02 on the handling and ride. I just recommend Stranos to anyone, and anyone that has ever ran a strano set up will recommend them over any spring as well.
Old Oct 30, 2012 | 10:02 PM
Blackbird-WS6's Avatar
I have BMR springs with 11inch wide rim (315 mounted) and have no problems
Old Oct 30, 2012 | 10:21 PM
Thought I'd post up a pic, again this is a Stano/ Bilstein set up, this is also WITH the rear isolator in, I took it out and now the rear sits about half an inch lower than in the pic above!
Old Oct 30, 2012 | 11:26 PM
[url=http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=369169]
What's the height on the back tires? I have 315/30/18s and stranos and mine just seems to have more wheel gap in the back. No biggie though. I like my stance.
Old Oct 30, 2012 | 11:33 PM
sometimes pinion angle, susp setups, rear axle tube size will make the rear sit higher or lower on other cars
Old Oct 31, 2012 | 10:40 AM
Those are 315/35/17 ET Street Drag Radials, and like I said thats with the rear isolator in, I did the heater hose mod with the thinnest heater hose I could find and it sits about half inch lower now, if your wheel gap in the rear is a little big for for taste I would recommend doing that, even with that I didn't have to roll my fenders with the Stranos, just a little BFH mod on the inner wheel well.
Old Nov 1, 2012 | 09:10 AM
SuperSport01's Avatar
Strano
