Lowering spring clunks on the rebound
Old Apr 12, 2004 | 09:35 AM
11 Bravo's Avatar
Default Lowering spring clunks on the rebound
My left front spring makes a loud clunk on bumps when it rebounds. Someone told me this was normal? I assume it's the spring because I checked for any loose bolts or other parts. Anyone else have this issue?
Old Apr 13, 2004 | 11:33 AM
Edrummr's Avatar
This guy reported a sismilar issue. He found the problem to be the nut on the shock tower. It's a pain to tighten down because the shaft will just spin. He ended up using an impact to get in all the way down.
http://www.metalreviewcentre.com/bmr.htm
Good luck.
