Swaybars for a staggered setup
The goals I am trying to accomplish is a more responsive feeling in the handling of the vehicle and an overall flatter cornering vehicle. There are no plans to do any autocross or road racing. I would like to stay with hollow swaybars only in order to save weight. Right now I am running ground control coil overs (550lb/in springs up front 160lb/in springs out back), Bilstein shocks, poly roto rear LCA's, poly/poly panhard rod, relo brackets, 2 point SFC's. I am torn between going with the Strano bars since (35mm/22mm) and the BMR bars (35mm/25mm). My reasoning behind possibly going with the BMR's is because I am running a staggered wheel and tire setup...18x10 Riken Raptor 275/35/18, and 18X11 305/35/18 555R drag radials out back. I am thinking that since the Strano bars are set up around a non staggered set up, I might be better off going with the 35/25mm BMR's because I have such a large differential in grip from front to rear. Thanks in advance everyone.
For a lot of people who just drive on the street, they just want a quicker response and stiffness in their car. If that's the case then going with bigger bars is probably better all around. While it makes it tougher to control on a road course, lots of people dont see a road course nor drive the car at limits like that. So stiffness makes the car feel like it's got a better suspension to them.
If you want more of my definition of handling, then you want Strano's bars with the adjustable rear bar. That will give you something around the range of the 25mm hollow when on the highest setting, better for drag racing. All other situations, the lowest setting is most likely key.
- Kevin
See, 1mm in bar diameter adds a lot of roll stiffness. And it's exponential. 1mm added between say 21 and 22mm is a bigger increase than 1mm added between 17 and 18mm (just example numbers, not anything f-body specific size wise).
I'll go a step further. *IF* you were hell-bent on a 25mm bar, I have those too.... I just don't list them on the site because I don't think it's a wise way for most folks to go, and I have an adjustable version of that as well.
