Rear Discs.
Old Apr 14, 2004 | 03:34 AM
BADz2ATE's Avatar
Default Rear Discs.
Ok guys, i have never done rear brakes on my 99 Z yet, is the E brake a drum setup where it works on the inside of the bell of the rotor? or is it through the caliper? just want to know what i am getting into this weeked. Also are Bosch Ceramic pads good for I rotors or no? I dont have the money for 100.00 Hawk, or high performance pads, so i want to get the best for about 50.00 at the most a set. i figured ceramic would be ok, gonna try to find Raybestos. Thanks in advance
Mike
Old Apr 14, 2004 | 05:05 AM
mitchntx's Avatar
The e-brake and caliper are seperate. The LS1 F-Bods have a tiny pad and drum set up.
Can't help you on the pad call ... If your funds are limited, then run what you can ....
Old Apr 14, 2004 | 01:13 PM
BADz2ATE's Avatar
does the pad and drum setup run on the inside of the rotor? or is it a seperate bolt on assembly, that the rotor slides over? thanks for the help.
Mike
Old Apr 14, 2004 | 01:17 PM
VIP1's Avatar
Copy & Paste Moderator
The parking/emergency brake is a drum setup inside the rear rotor.
I'm currently using Satisfied Metalazer Pro Ceramic in the front and metallic in the rear. They are about the same as stock. They are a brand that Lappens carries.
--VIP1
