subframe connectors do subframe connectors really help that much and circle or boxed connectors |
yes..very much. i went with these, along with everything else UMI offers for my car and am VERY happy with the results.... http://www.umiperformance.com/catalo...roducts_id=193 |
does it make a big difference if they r bolted on or welded in? |
welded is better..less flex. but mine are bolted and still made a huge difference. |
I went with 2 point weld in connectors and they did nothing but lighten my wallet and add weight to the car. I went tubular because they tuck up, are hard to see and I lost no ground clearance. I wouldn't buy again. |
and you can always bolt in and go back and weld later if need be.... |
Originally Posted by carbed86fox
(Post 16980713)
do subframe connectors really help that much and circle or boxed connectors IMO no, they don't. I have 3pt bolt in that are welded, they did nothing, but that being said I already fixed the actual problem, the shitty stock shocks. If you want a solid, stable car that feels planted and well behaved you need good shocks, period. |
i have some lake wood 50 50s in the rear and i just dont like the feeling of how much the drivers side picks up when it hooks i can just feel it twisting even from a roll |
and yeah i wouldnt wanna weld something to my car if it wasnt going to work or not |
Originally Posted by JD_AMG
(Post 16981130)
Depends on who you talk to. IMO no, they don't. I have 3pt bolt in that are welded, they did nothing, but that being said I already fixed the actual problem, the shitty stock shocks. If you want a solid, stable car that feels planted and well behaved you need good shocks, period. I have not done SFCs yet. Dont know if I will. MWC says if you do them make sure they are welded. |
ya thats what everyone is telling me that they should be welded but i heard the boxed ones will twist |
if you are drag racing, subs are essential...anyone who says different has no idea what they are talking about. just like you said...the drivers side lifts up and twists the car... |
If you say they do nothing, you obviously havent seen creased 1/4 panels that result from flex, which never happens on a car with SFC's |
MWC /thread |
Originally Posted by Amazin1
(Post 16980725)
love mine...UMI 3 point......must have in my book |
Oh, and typically tubular for better ground clearance, and boxed will kill about 1/2" of clearance.. not really that big of a deal, IMO. 3pt is a tad bit more rigid, but 2pt works fine if you're on a budget.. nothing wrong with them though. Still just as effective.
Originally Posted by senicalj4579
(Post 16981226)
This is what Sam Strano will also say FWIW. I have not done SFCs yet. Dont know if I will. MWC says if you do them make sure they are welded.
(Post 16981130)
Depends on who you talk to. IMO no, they don't. I have 3pt bolt in that are welded, they did nothing, but that being said I already fixed the actual problem, the shitty stock shocks. If you want a solid, stable car that feels planted and well behaved you need good shocks, period. |
same here...i lowered my car with eibach springs and tokico's and then i did my subs and i noticed a difference... |
^ I couldn't believe that it even effected braking performance! Un-fricking-believable difference. And before them when I would spin em from a roll, the car was rather unpredictable.. After SFC's, it would spin straight and was much more predictable and was more controllable. Get it loose and a degree or two off center, then just gently crack the wheel over to the other side and she would slide right over and straighten out. Such a difference in control. |
Originally Posted by VinR1
(Post 16981531)
MWC /thread |
© 2024 MH Sub I, LLC dba Internet Brands
