Leaking Brake Issue
I was installing new rotors in the rear this past weekend when i noticed the right rear brake is leaking, its not coming from the caliper or a hole in the lines..
It appears to be leaking out of the bottom section that deals with the E-Brake i think.
Im stumped on what i need to replace or how to fix this leak, this could be the issue with my abs because the leak is covering the speed sensors and hub
