Adj. LCA's?
Old Feb 9, 2013 | 01:47 PM
6togo's Avatar
Default Adj. LCA's?
When are adjustable control arms really needed i'm going to be upgrading soon and dont know if they would be worth the extra $$ if they never need adjusted on the street!
Old Feb 9, 2013 | 08:01 PM
Blackpanther99's Avatar
Are you planning on doing some drag racing?
Old Feb 9, 2013 | 08:35 PM
6togo's Avatar
Mostly a street beater maybe a pass down the 1/4 every now and then. I plan on doing a adjustable TQ arm and i have a adjustable Panhard bar for when i pun the lowering springs in.
Old Feb 9, 2013 | 08:57 PM
UMI Sales's Avatar
Factory housing and unbent car is great with non adjustables.
Aftermarket housing, bent car, or desire to fine tune thrust angle are a good time for adjustables.
Aftermarket housing with verified alignment can use non's.
From an engineering standpoint I like non's for simplicity. On the flip side, if you have a desire to fine tune, adjustables are nice...
Old Feb 9, 2013 | 09:52 PM
redracer1's Avatar
If its mainly for street use there's no reason for adj. Only recommendation I'd make is UMI poly/roto-joint.
Old Feb 9, 2013 | 10:02 PM
6togo's Avatar
Stock housing atleast for now and i dont think its bent! All i normally run is UMI!
Old Feb 11, 2013 | 04:03 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
I think you'll be fine with non-adjustables. For the T/A, I would ONLY suggest an adjustable as well as the panhard bar.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
