Help, Knowledge of NPT O-rings
I had to replace a Wilwood clutch MC and an O-ring NON tapered nipple came on it from Keilser.
Are the O-rings suppose to fit snuggly in the hole or be compressed in between the components? My problem is I can't find a single O-ring that will fit around the bolt and fit in the hole.
Make sure the o-ring you install is designed for the enviroment, the fluids can be very corosive to some rubber products. So the one you fine at the local hardware store might rot out in a month. I would suggest checking with either the source you purchased it from or Wilwood.
In my experience Wilwood is very help full with tech issues.
