please help with alignment
Old Apr 20, 2004 | 02:20 AM
z28viperkiller's Avatar
Default please help with alignment
i have stock suspension components.. stock hight springs. i will be lowering soon. i need more neg camber for auto x . all i get is about .5 deg neg max. and about 3- 3.5 deg max caster. the only thing i could think of is to slot the lower control arm slots or to shorten the upper control arm somehow. anyone have any better ideas that work? My brand new Kumho victoracers are wearing on the outer edge.. tells me i need more neg camber. im out of slot to play with.. any ideas??
Old Apr 20, 2004 | 04:37 AM
mitchntx's Avatar
Once you lower the car, you will be able to get more negative camber.
Till then, slotting is about your only alternative.
