LCA Relocation Bracket Question
Old Mar 21, 2013 | 08:15 PM
TA1364's Avatar
Default LCA Relocation Bracket Question
My car has non adjustable lca and running a 275/60, if I put relocation brackets on and use the lowest hole will it pull to tire to far forward to fit? Or do I have to have adjustable control arms to make this work.
Old Mar 21, 2013 | 08:29 PM
UMI Sales's Avatar
Properly designed relocation brackets (like ours) do not require a different or adjustable arm. The holes are drilled to follow the arc inscribed by a 19-1/4" arm.
Old Mar 21, 2013 | 08:33 PM
TA1364's Avatar
Thanks! They are going to be UMI. I am assuming the lowest hole is best for stock height/drag setup?
Old Mar 22, 2013 | 07:42 AM
UMI Sales's Avatar
We usually use the lowest hole for drag, next hole up for general geometry correction on a lowered car.
Thanks for considering UMI!
ramey
Old Mar 22, 2013 | 11:50 AM
Founders Performance's Avatar
Most of the relocation brackets including ours do not require adjustable lower control arms.
Old Mar 22, 2013 | 02:56 PM
Zlow28's Avatar
What do adjustable LCAs help with then?
Are they to help adjust tire size?
Old Mar 22, 2013 | 03:25 PM
SparkyJJO's Avatar
From what I understand they are useful when using oversized tires when trying to stuff as much rubber as possible in the wheel well, or when using aftermarket rear ends to help recenter it if they aren't designed with stock length arms in mind.
Old Mar 22, 2013 | 03:42 PM
john563's Avatar
sam i have non adjustable lower control arms...mine is set in the lowest hole
Old Mar 22, 2013 | 04:08 PM
UMI Sales's Avatar
We use adjustable lower arms to fine tune a bent car, fine tune when running an aftermarket rear housing, whenever we need to adjust thrust angle or whenever we want to recenter a wheel in the wheel well.
We have house cars with adjustables as well as house cars with non-adjustables. Both work well for their intended application.
Lowering does not automatically mean adjustables are required.
ramey
Old Mar 22, 2013 | 09:19 PM
Zlow28's Avatar
great to know. Thanks.
